  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
In-wall for 5.1 & stereo
A8RICK
Im looking for some help choosing speakers & hoping you guys can point me in the right direction?
I will try and give as much info as i can:-
The room is 5.7m long x 3.2m wide.
looking at the 5.7m TV wall - To the left is a double opening into the dining room, then about 1/3rd along is a cassette type log burner, next to this (about 2/3rd's along) is the TV. to the right is the window. Sofa is directly opposite the TV.
(tried to post a picture of the room but gave up? sorry!)
What im thinking is - In-wall speakers left/centre/right around the TV (its a floating wall set-up), with ceiling speakers above the sofa as the room is so narrow?
I was looking to spend £1000 - £1500 for all 5 speakers (ive only ever had standard TV speakers so anything should be a step up for me!).
Compromise is i would like to use the front left & right for music. therefore is it worth spending extra on these with that im mind? i was thinking along the lines of the B&W CWM LCR7 for the left & right, maybe something cheaper for the centre & rear. I will purchase a sub later but will take any suggestions.
can anyone suggest a good set-up for my budget? Also any suggestions to power them?
Cheers,
R.
Andrew K
Close to an in-wall option but worth considering are the Monitor Audio Shadow speakers. They are excellent for music and movies but are slim on-wall speakers.
A8RICK
Thanks,
Not seen these before, must say they do look very good and seem to get good reviews.
On the down side, its a bit of a shame they dont come in white, plus they are right at the top of my budget (although i could just use a pair of S50/60 as the main offereing i suppose, and save for the rest).
I dont think they are quite right for me as im after flush fitting ideally in white, but out of interest, do you thing these could be set into a very shallow wall recess, effectively making the grilles flush to wall? or would this affect the sound?
Cheers for the suggestion,
R.
Andrew K
Thanks,
R.
Yes you could set them in so they are flush to the wall.
