In the Pink please help
Discussion in 'TAG McLaren Audio Owners' Forum' started by abspag, May 29, 2005.
  1. abspag
    abspag
    All I can get as an output on the dvdflr is either the vca connection to my tv this works if I try the bnc connection to the prj its pink it seems like the psm is not working please can anyone help
  2. hoosterw
    hoosterw
    Dec 14, 2004
    16
    in NL near Eindhoven
    Does the DVD has the PSM or not?
    I think there is a mismatch between the output format of the DVD and what the prj is expecting as input, then often it turns up pink.
    Try switching the DVD to a different output format, probably it will get right.
    Or set the prj to the right input format.
  3. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    you need to be aware that the BNC output can give RGsB or Component when a PSM is fitted (this is covered in the manual) try setting the output to Component.
    EDIT from the manual -
    configuring the PSM192 video outputs
    The digital and analog video outputs can be configured as component (YPbPr) or RGsB (i.e. RGB with sync on green). The output mode can be changed only when the player does not have a disc loaded. To change output mode, remove any disc that is loaded, close the door, and wait for the no disc message to appear. To select COMPONENT press the number keys corresponding to the letters COM, i.e. 2, 6, 6 on the system remote. To elect RGB press the number keys corresponding to the letters RGB, i.e. 7, 4, 2.
  4. abspag
    abspag
    Thanks for the reply. I have used the rgb and componet codes with no luck it still appears pink. I was wondering if the psm card is faulty. Does anybody know how to test the psm digital output
  5. roversd1
    roversd1
    make sure your pj is set to expect rgb or component.
    This was a regular question to the Helpdesk, it was always a format muddle rather than a PSM problem.
    From memory, your screen is set to recieve component but is recieving RGB from the player = pink screen
  6. abspag
    abspag
    Thanks for all yor help. The problem was with the projector in the menu a setting for colour space needed to be set for rgb and this sorted the problem :clap:
