in phase?
Discussion in 'Home Cinema Speakers' started by H4r7y, Jul 23, 2003.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    is there anyway to be absolutely sure that a pair of speakers are all in phase, ive been told alot of different things about this.
    or is it a big myth?
  2. nathan_silly
    nathan_silly
    Check polarity on speaker wires (red to red, black to black etc) or Avia phase test tones if you don't have access to the cables (ie in wall fixings) or use a multi meter on (continuity?) test- when you create a circuit between the two probes the meter will beep, so put one probe on either end of the cable.
