Huxley
Hi, I'm new. I've just joined and hope to get some advice about my situation.
I don't have a lot of money to spend on HiFi, and quality stuff is very expensive where I live, but I've been able to knock a system together that is sounding pretty damn good to these ears.
I'm using a 200w Douk/Nobsound mini-amp and a pair of Yamaha NS F150 floor-standing speakers. These speakers are 6 ohm with a frequency response of 37Hz to 30KHz. Really I could just leave it at that and I'd be quite happy.
However, I recently got made an offer I couldn't refuse on a couple of Monoprice 8 inch powered subwoofers. I've wired them both up to my amp using the speaker-level connections. What I've found is that I can barely turn them up because the bass response of the Yamaha speakers already goes down pretty low. I currently have the subwoofers set on the minimum volume setting and turned to their minimum low-pass frequency which is 50Hz. Everything sounds great, but there's a lot of power that the subwoofers could be adding to the system that would seem to be going to waste.
I just bought a couple of 400 uF capacitors rated at 100v. I have heard that if I put these in-line with my speaker connections it will cut the low frequencies < 100Hz of my Yamaha speakers therefore allowing me to turn up the subwoofers and perhaps get more clarity in the midrange from the Yamaha speakers at the same time. I am a complete novice at this sort of thing, any advice about this and whether it will work or is even worth doing would be very much appreciated. I wanted to check before I try wiring those capacitors. Thanks!
