In light of lack of Samsung 950
Discussion in 'Blu-ray & DVD Players & Recorders' started by sandstheman, Jul 15, 2005.
  1. sandstheman
    sandstheman
    Jan 6, 2005
    545
    28
    +49
    Any recommendations for any other DVD players, budget up to £200.
    Will be connecting it to a 37" Sharp LCD, my requirements are:
    must have component connections (what dvd players don't these days), and also preferably DVI out (Non HDCP or at least with a hack to be able to turn HDCP off), multi-region, upscaling over component/DVI (i assume if it can upscale it will have pal/ntsc progressive output as well), not concerned with onboard aduio decoders as it will be connected directly to my amp (Denon 3802). Image quality is top priority, then sound quality, looking for a nice design and good build quality.
    Anything out there that will fit the bill and do my existing equipment justice, seems like the samsung just keeps getting delayed further and further, so looking at other options now
  2. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    Pixmania have the 950 due in next Friday, according to their website.
    Probably worth holding out.
  3. sandstheman
    sandstheman
    Jan 6, 2005
    545
    28
    +49
    It's due in 29th now the dates been changed
    I been waiting for over a month now, currently without a dvd player, had to resort to using x-box which is ok but not getting the best out of the screen, and still no sign of it, thats why i'd like to know if there is any other player out that'll give me what i'm looking for
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    May be worth hunting for a 745? Pixmania site suggests they can be had from their "Fulham Pickup Point"...PJ
  5. cjp123
    cjp123
    Nov 2, 2004
    77
    Are we saying that there are no other players worth considering within the £200 budget range ? What about the Pana s97 ? are they not as good ? I too was waiting for the 950 and I am getting fed up waiting as well. I have new LCD and am using a poineer 565a on S-Video so far but want to try upscalling. I dont really want to spend £40 on some decent componant leads so that is why I was getting the 950 as it comes with DVI cables so any more suggestions on upscalling MR players would be great.
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    s97 is a good player by all accounts, you'll need a HDMI to DVI adapter... but if you are happy to do that the Samsung 850 is an option too?
    ...PJ :)
  7. zoro
    zoro
    Jan 23, 2003
    325
    +7
    PJTX does your S97 do Pal to NTSC? and dual voltage?
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    don't have an S97, have a Samsung 745...PJ :)
  9. MWD
    MWD
    Oct 20, 2004
    161
    16
    S WALES
    Check out the thread on the Oppo 971 dvd player - getting good reviews and passing the tests on hometheatrehifi site. Im also on the search for a good dvi player and have waiting and waiting for the sammy for so long that I think im gonna go for the Oppo or the phillips 9000 [tempting for the good reviews its getting on sound quality].
    Hope that helps and the Oppo is definitely sub £200 leaving enough to buy a quality dvi cable.
  10. Stevie D
    Stevie D
    Jul 10, 2005
    117
    Scotland
    +5
    Forget the Pany S97 it's like gold dust no one has any I've given up :mad:
  11. nnicol
    nnicol
    Feb 4, 2005
    231
    3
    19
    +11
    For the Panny s97 try www.multizonedvd.com , I ordered one yesterday for £149.86 plus £20 for multi-region. They are still taking orders so if you want one try them. Hopefully I will find out today when mine ships. I hope they have stock and the website is not out of date.
  12. Stevie D
    Stevie D
    Jul 10, 2005
    117
    Scotland
    +5
    Thanks nnicol I'll give them a phone tommorrow :D
  13. DaveP
    DaveP
    Sorry to jump in but can you turn off HDCP on the S97?
    Dave
  14. BeStu
    BeStu
    Feb 18, 2005
    164
    16
    France
    Nope! :thumbsdow
  15. BeStu
    BeStu
    Feb 18, 2005
    164
    16
    France
    Sorry back again! Pixmania.fr still have HD945 available :thumbsup:
  16. Paul101
    Paul101
    Jul 24, 2005
    Where can you get the Oppo 971 from?
    Website says it comes with DVI cable, wouldn't the quality be good enough?
    Also, I'm a bit confused :confused: , does DVI carry audio like HDMI, I'm sure I read on a thread somewhere that it doesn't ?
  17. jason.bond
    jason.bond
    My hd950 just arrived from pixmania.
    They must have a backlog, but they are getting them through.
    Be patient.
  18. Stevie D
    Stevie D
    Jul 10, 2005
    117
    Scotland
    +5
    950 £136 delivered from RS :)
