IN EAR which Model
Discussion in 'Headphones, Earphones & Portable Music' started by Tobez, Jul 29, 2004.
  1. Tobez
    Tobez
    Ok seem to be a few debates on this topic.
    My issue is i have an Ipod and want some earphones to complement is as the original 1s, you get are poor.
    I originally had the Sony fontopia cant rem model but retailed at 35 i think. but for some reason ive lost them. Ive come to a comclusion that i want a good set, ive been looking at the ER4P by Etymotic, and also seen the £20 mx500s.
    Has ne1 got any of the above and tested both, are the ER4P worth the £239.00 or can ne1 reccomend anything better than my old sonys for fullness etc. I did come across these babys but that is overkill
    http://www.ultimateears.com/UE-10_PRO.htm
    Thank in advance
    P.s i can afford the ER4P but am i wasting my Money ?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    I've got a set of the cheaper Etymotics here,and I'd say you get most of the good points minus a little of the detail etc,but at a much more manageable price.
    It's fair to say though,that the ER4P's are more comfortable for longer term wearing,and perhaps a little less fiddly,but either will offer you some very good listening.
    Part of the cost of those UE 10 phones is in the custom ear fitting....it will give you the best possible fit etc,but as you say,overkill.
  3. davet010
    davet010
    Jul 23, 2004
    384
    +10
    Get hold of a pair of Shure e2c's or e3c's (£55 or £110) - excellent once you get used to them.
  4. nikyzf
    nikyzf
