In ear Headphones
Discussion in 'Headphones, Earphones & Portable Music' started by meirion658, Aug 21, 2013.
  1. meirion658
    meirion658
    May 12, 2008
    150
    +18
    Hi all I am looking a for a good set of in ear headphones to use with my phone, listening to music while commuting to work on my motorbike. Budget wise I am not looking to spend more than £50. Any suggestions would be of great help.
  2. Member 266567
    Member 266567
    Mar 18, 2008
    584
    Near Brighton
    +81
    Hi meirion658,
    The SoundMAGIC E10 is possibly the best in-ear under £40. The SoundMAGIC E30 would also be a good choice as they fit closer to the head, this will make them better for use with a bike helmet.
  3. jamung
    jamung
    Oct 24, 2011
    234
    28
    +28
    E10s are good buy but if you have a bit more budget I suggest the Shure SE215. :)
