in ceiling speakers
T
TWMB
tried this in speakers forum but got no response - starting loft conversion shortly and will need in ceiling rears on a 5.1 system (front/centres will be monitor br5's/lcr) but one will be mounted in sloping ceiling and one in flat ceiling so looking for something with some directional adjustability, any suggestions greatly appreciated. alos as its a loft conversion wont have a huge amount of depth to play with.
T
TWMB
Thanks, Have Seen Those But Just Need Something With A Bit Of Directional Adjustment Within The Enclosure
andyman2
Speakercraft Aim8 series have directional tweeters. I use these as fronts, due to circumances beyond my control - but have been very pleased with them. I believe they do a range from about £180/speaker upwards
Andy
andyman2
Actually that was not entirely correct. Looking last night reminded me that both the bass and the treble can be angled independently.
NonPayingMember
Previously Liam @ Prog AV
I mainly use speakercraft for our jobs.
Could box out a small section of the flat ceiling to match the angle of the sloping one... wouldn't be more than a few bits of wood and a lick of paint. Make it about the size of a regular speaker box but cut down it's diagonal.
hornydragon
Lots of manufacturers have movable tweetersa few are fully movable with the confines of the outer casing Sonance is one i seem to remember
NonPayingMember
This one ideally wants tilting bass drivers as well as tweeters. Speakercraft again do this in most of their ranges, there's the excellent AIM WIDE range which are perfect surround speakers - not because you can angle them but because they disperse in every direction!
http://www.speakercraft.com/#Products:410:AIM%20Wide One
Or maybe use some AIM LCR speakers where you tilt the whole unit in the wall.
http://www.speakercraft.com/#Products:410:AIM Wide One
Depending on aesthetics I do still like the idea of just boxing out a small section of the sloping ceiling to make the mounting position exactly match the non-sloping ceiling (or vice versa).
