Kevin Harris
Hi Guys,
Looking to change to a stealth HC setup in my living room and one of the first things I would like to do is to replace my 2 side and 2 rear Speakers and put them in the ceiling. My main concern is I might lose the whole surround effect.
Is putting all 4 Rear speakers in the ceiling only good if it is the only choice you have or is this as good as the speakers mounted on the wall.
Has anyone done this and found it to be successful or reverted back to mounting the Speakers on the walls or even went for a combination of both.
Any advice welcome before I cut big holes in my ceiling.
Kevin
Kevin
