in ceiling speakers - amps for?
Discussion in 'Home Cinema Control & Remote Controls' started by vikingboy, Jun 8, 2003.
  1. vikingboy
    vikingboy
    May 31, 2003
    83
    berkshire, UK.
    I have seen some in ceiling speakers from Linn which look like they are going to do a good job of producting audio. I'm going to use one pair in the bathroom and one pair in the kitchen. They require a two channel amplifier each, ideally I'd like to mount the amp in the loft space too so a unit which is switch on and forget would be ideal.
    Any suggestions, will only need to be around 35w-ish.
    t.i.a
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,979
    +2,780
    What Linn speakers are you talking about?
    Linn themselves do asimple thig called a room amp that is designed to screw on to wood joists or MDF etc. Alternatively I like to se good quality s/h integrateds or power maps for this sort of application. A nice s/h Arcam P8 power amp could be ideal.
    Gordon
  3. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    FYI we have a unit coming at Arcam in the next few weeks which might suit your needs, based on the new A80 integrated. It includes signal sensing so consumes very little power unless you actually send it music.
    It is called the P80 (we have always been imaginative with our product naming!) and will retail for around £420. Output power is 65 WPC.
    HTH,
    John Dawson (Arcam)
  4. vikingboy
    vikingboy
    May 31, 2003
    83
    berkshire, UK.
    See the sweetspot or the diskreet. Details are at:-
    http://www.linn.co.uk/spec_sound/products.cfm?range=loudspeaker
    scroll down to the bottom.
    I've been thinking about this some more. I'm going to need an amp which has remote controlled volume also, or somehow connect it into a volume control panel on the wall.
    thanks for your help guys, its appreciated
    Ian
  5. vikingboy
    vikingboy
    May 31, 2003
    83
    berkshire, UK.
    Gordon - can you post link to any details on the Linn Room amp, that sounds like it might be what I'm looking for but I coudnt find details on Linns site. I always seem to end up looking at the CD12 and their mono amps <drool> :)
    cheers
