in-ceiling screen advice needed
Discussion in 'Projectors, Screens & Video Processors' started by 18j, Aug 6, 2006.
  1. 18j
    18j
    Mar 4, 2002
    108
    16
    i'm in the middle of building an extension to the house that will give me a room about 15ft x 9ft and want to set up a projector and screen, probably an in76, so can i mount any of the electric screens in the ceiling void leaving a letterbox slot for the lowering of the screen or has it got to be certain types ?
  2. AV Nik
    AV Nik
    Jul 11, 2006
    581
    46
    +100
    Hi 18j,
    There are specific screens available called 'Recessed Screens'.
    The best I have used are the Projecta 'Advantage Electrol' and the Draper 'Access Series'. Both professional quality with 5 year motor warranties.
    With these, you can install the recess case easily and then the screen slots in afterwards. Some recess cases are available with the option to install other electric screens.
    Checkout these manufacturers:
    Projecta
    Draper
    A DIY alternative would to fit the screen between joists or above a suspended ceiling, replace the ceiling underneath it with the appropriate slot for the screen to lower through.
    Hope this helps?
    You should receive more answers from other people too.
    AV Nik
  3. 18j
    18j
    Mar 4, 2002
    108
    16
    thanks nik but they are more than the pj i planned to buy :eek: . looks like i may have to try and make something up !
  4. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi, I jfitted my 7ft electric screen to the celing then built a 2x1" frame round it then covered with plywood left a slot then decorated it in the same wallpaper as the rest of the room. pretty easy and cheap really. Mike
