In Ceiling Mirror System - Options & Where to Buy?
DannyTucker001
Evening all.
I'm looking for some information on a mirror system for a projector installation. I have limited head room and a lift is quite expensive so I am looking at the idea of a mirror system.
1. Does anyone have any experience of these?
2. Where can I buy them?
I will be using a Sanyo PLV Z700.
Much appreciated.
Regards.
NonPayingMember
Previously Liam @ Prog AV
Mirror is also expensive and will be very susceptible to dust and alignment problems. There are one or two cheap projector lifts available, they are only small but the Sanyo isn't that big anyway. We sell a Beamax projector lift fo £740 inc VAT which is like half the price of the next model we sell from the likes of Future Automation.
DannyTucker001
Many thanks Liam. That is by far the best priced lift I've seen to date. Sadly it doesn't appear it can be IR controlled?
78G
Hi Danny
Try Puretheatre.com they have lifts starting at £750, they may be able to be controlled via IR
NonPayingMember
It's the same as a projection screen in that it has a 4-core cable coming out of it which you can use with any Beamax controller - IR, RF, 12v or a wall switch. You can download the manual from the Beamax site:
Beamax | projector lift
