in car
Discussion in 'Headphones, Earphones & Portable Music' started by lovemunkey187, Apr 7, 2005.
  1. lovemunkey187
    lovemunkey187
    Aug 19, 2004
    2,603
    71
    Notts/Sth. Yorks border
    +29
    I'm wanting to get an mp3 player for my car.
    At the mo' a standard Ford radio/cassette is installed, so it needs to be compatible with this.
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
    Nothing is strictly compatible. However you have a number of choices:
    An FM transmitter which plugs into the player and broadcasts on an FM frequency that you tune your radio to, convenient but ever so slightly illegal
    A cassette which plugs into the line out/headphone socket of your player and goes into your cassette player in the car
    An FM modulator which is wired to the ariel lead and which then allows the modulator to transmit direct to the car radio
    A direct link to a line in on your car radio, which is usually a CD changer socket, if there is one.
    Have a search on this forum for more details and on player specific sites as well such as www.ipodlounge.com
  3. kyza
    kyza
    my mate uses the casette thing simon mentioned for his car, it works really well, sounds perfect
  4. lovemunkey187
    lovemunkey187
    Aug 19, 2004
    2,603
    71
    +29
