In car sound
Discussion in 'Headphones, Earphones & Portable Music' started by Chox1988, Sep 3, 2005.
  1. Chox1988
    Chox1988
    Mar 30, 2005
    16,783
    basingstoke
    +9,157
    I have a NW- HD1 and am wanting to play it through my car's speakers but don't have an aux input on my headunit, can't afford a new one yet. So was wondering whether I should go for the fm transmitter or cassette adaptor. If so any recommendations.
    Cheers.
  2. djpowell
    djpowell
    I had a Goodmans cassette adapter that came in a pack with a power adapter, and a ridiculous goose-necked mounting bracket thing. The sound quality was very good, but I pulled the wire out of it. So I bought a cheap no-name one from the supermarket expecting them all to be the same, but the sound quality was awful. It sounded like AM-radio. I foolishly bought another cheap one and that was just as bad, then I bought a Sony one, and that was good, but perhaps not as a good as the Goodmans one. So I'd recomend either Goodmans or Sony.
    From what I've heard FM trasmitters aren't as good as cassette adapters, but I've never tried one myself.
    Dave
  3. dq1967
    dq1967
    Mar 14, 2004
    30
    I bought a Goodmans for my NWHD5H and it sounds crap I'm afraid. I'm trying to get a Sony CPA 9 just now, but they're as rare as hen's teeth just now. Let us know what you do and how you get on.
    dq
  4. DaveA
    DaveA
    Aug 26, 2004
    70
    Chester
    I dug out a panasonic cassette adaptor from an old CD walkman (remember them??!!? :D ) - the sound is there, but essentially sounds rather like a cassette - mainly because it's going through the cassette's input mechanism.
    Highs and lows tend to be overdone, with the midsound being slightly muddy.
    Fortunately i've got an amp in the back of the car, and wiring in direct is great! I just haven't run the cables through yet.
  5. Uridium
    Uridium
    Jan 29, 2005
    14,415
    North West Leicestershire
    +1,855
  6. dq1967
    dq1967
    Mar 14, 2004
    30
    well spotted, they were quoting 4 weeks last week !
  7. DaveA
    DaveA
    Aug 26, 2004
    70
    Chester
    Other choices are Dension Icelink or Connects2 adaptor. Both in the £50plus price bracket though, but much superior sound/functionality.
  8. Chox1988
    Chox1988
    Mar 30, 2005
    16,783
    basingstoke
    +9,157
    Cheers everyone for teh responses. I think I'm gonna go sell blood and invest in either an expensive cassette adaptor or an AUX input type thing on the headunit. Only problem then is I want a subwoofer (strokes chin and contemplates how much blood he's got)
    :thumbsup:
  9. DaveA
    DaveA
    Aug 26, 2004
    70
    Chester
    Abu - try the Infinity Basslink. Very good - easy install - auto sensing on the inputs (high level speaker taps/rca if you have em). Auto power off etc.
  10. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Best bet is to get a decent head unit which has a aux in.
    I bought this head unit from Argos for £165. It is from their last catalogue and therefore isn't on argos.co.uk anymore. It is really nice, if you want a new one I recommend this one. Catalogue number 500/3514, worth checking if it is in stock at your local store!
    It has a phono line in on the back, I just have to work out how to plug a jack-RCA cable in and get the jack cable round the front!
    Or I could get a Connects2 kit, which are £50 from Halfords.
  11. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    LOL I like the way Halfords describe it as having "the ability to play MP3 and ATRAC2"...... :rolleyes:
  12. Sasso
    Sasso
    WIth my HD5 on line out I use a Sony cassette adaptor model CPA-8. Its from an old sony car diskman but I never used it. Whats the difference between the cpa8 and cpa9?
    The sound quality is excellent, sounds just as good as if I had the CD in the stacker. The bass is clean and good (depends on car stereo) and it doesn't sound like it has lost any quality (like on tapes). FM tuner would be handy in some cases (like if you dont have a cassette in your car) but i would have thought it would sound like radio (crackly and slightly less quality) unless like the cassette it just depends on the source so it may sound better than radio.
    Only problem I have is that sometime when i put the tape in it musn't go in properly and the operation is slighly noisy, then it auto reverses the tape and doesnt play sound, but all I have to do is take the tape out and put it in again, then it plays quietly for ages.
    It has a little slider thing on the thicker side of the tape that has a left, right and centre position, its called cross talk or something, what does this do, it didnt make any difference (that i heard).
  13. Chox1988
    Chox1988
    Mar 30, 2005
    16,783
    basingstoke
    +9,157
    I like the looks of that Infintity Basslink. *To ebay and beyond*
    Cheers. :thumbsup:
  14. HD3
    HD3
    As i suggested in another tread;
    "Rather than using a transmitter why not chose a FM Modulator/Oscillator
    such as this- http://www.maplin.co.uk/module.aspx...o=44128&doy=6m9
    You connect the device to a lineout/ head phone out on your mp3 player and you plug a lead into the FM input of your car radio. (and don't worry, you don't lose your fm singals as they have a "Pass-through FM aerial connector"
    Perfect for a sound q boost better than FM transmitters and likely better than tape. The best is having a "aux" in on your radio/CD but not many have that function.
    As for MP3 players, i don't think you can go wrong. Get something you like
    P.S- I made one from a soldering kit. :devil: "
  15. Chox1988
    Chox1988
    Mar 30, 2005
    16,783
    basingstoke
    +9,157
    That looks very interesting. Didn't think anything like that existed. I'd make one but not good enough with electronics. I'll fork out the twenty, not very expensive :clap: .
    Cheers.
  16. HD3
    HD3
    To be honest my kit one isn't brill and it takes abit of tuning, but i'm sure the bought one will be much better. I'd great it quick if u want one because its on promotion, let us know how it sounds. Hope it sounds ok.
