In-car Pal to NTSC converter?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by MirageZR, Oct 10, 2004.
  1. MirageZR
    MirageZR
    Does anyone know a way of converting UK PAL signal to work on a Japanese in-car TV unit?
    It seems there are household TV signal converters... Surely, all that's needed is a PAL to NTSC converter that runs using car voltage?
    I guess the next hard bit is making the converter compatible with the stereo/TV unit?
    any ideas???? :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try a 12v power adapter uniross probably make one.......... even the in-house ones probably use a 240V to 12V or 6V transformer....
  3. critch
    critch
    hi mirage
    is the tv unit also a dvd player or is it just a tft screen ?
    ps whay make and model is it ?
    cos one way maybe get a jap ps2 connected up to it :thumbsup: same format !!!
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,047
    +155
    Have you checked the source?
    ie a lot of dvd players will output NTSC even with a PAL disc.
  5. MirageZR
    MirageZR
    Thanks for your replies
    Not having too great a depth of technical knowledge myself, it seems as if I am looking for something that seems relatively simple, but is in fact not easy/possible (without too much time and expense - so I might as well just buy a UK unit).
    Basically the unit is Jap spec car stereo with built in TV (no DVD, only a sat nav external cd-based unit) - it therefore accepts only a Japanese NTSC TV signal. I was hoping to be able to convert the UK PAL1 TV broadcast signal to NTSC to be displayed on the screen. At the moment all I get is black&white with no sound.
    This is a problem that many people with imported cars face, as the stereos are often expensive units, so it seems a shame to either throw them away or not have all their functions working.
  6. paulmc
    paulmc
    Apr 24, 2005
    68
  7. ccoaton
    ccoaton
    May 1, 2005
    3
    :clap:
    I also have a Jap TV Tuner,..In dash one that Slides out,.Built in Tv Tuner And Screen,...When I plug in P/S or DVD and switch them to NTSC they Play Fine with great sound quality....
    But If i just use the TV it is in Black and White with No Sound,..So I take it that it only recieves in NSTC,....
    Those home Converters look great but am wondering if there is a way to plug them into my reciever to convert the Pal Signal to NTSC,..
    Any Help would be great,... :lease:
    Thanks ,........Colin
  8. paulmc
    paulmc
    Apr 24, 2005
    68
    I am going to use it for that very purpose.
  9. ccoaton
    ccoaton
    May 1, 2005
    3
    Hello..
    Let me know if it works Paulmc,..........Been searchin a while for the right add on but no luck,...Keep coming back to the Home Unit...
    Thanks,...............Colin
  10. Paul Scarbro
    Paul Scarbro
    Jul 27, 2014
    17
    4
    I know this is an old thread. Hoping somebody can advise non-the-less.
    I have a hi spec Jap head unit (cameras, TV, DVD, sat Nav, hard drive) and wish to convert certain parts.
    I am currently able to play audio from external devices. I can connect my phone for calls only.
    I now wish to play DVDs (PAL), TV (have purchased a Freeview unit), and convert the Sat Nav.
    Any ideas as to one or more of my requirements please?
