In-Car DVD Audio Help...
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by BullochDawg, Nov 15, 2004.
  1. BullochDawg
    BullochDawg
    I just bought a truck with an aftermarket under-seat DVD player (MobileVision) and a flip down KEC monitor. I am getting video from the DVD player as well as a weak TV signal on the monitor, but no audio in the speakers.
    Is it common practice to tie the audio into the factory stereo system, or is it just headphone audio only? I didn't try checking for audio using headphones. I played around with the factory stereo, thinking they tied it into an AUX channel. However, I never found anything that indicated any kind of AUX selection.
    I don't have any manuals and the previous owner knows nothing about the system. Any help would be greatly appreciated.
    Thanks.
  2. critch
    critch
    sounds like theres no aux in put on ur head unit so the sound wont come out as its not connected via so u could
    A : take the head unit out and see if there is a aux in put
    B : get hold of a set of speakers like for a walkman
    C : fm modulator (but not best quality so ive been told )
    D: get a new head unit with an aux input for best quality
