markymiles
At the very early stages of this, but considering literally pushing two FF Sub boxes into my unit.
Unit I have is this:
If I move things around I can have the outside compartments empty which will leave room inside for two boxes. The boxes can be 21" W x 17" H x 19" Deep. I was thinking I could squeeze a 15" driver in each. Volume around 70L net with a bit of polifill should be able to get 80l or so. Not decided completely on drivers yet but do favour the Si HT15's because they should run off my existing amp and also I like what I've read about their characteristics.
Before I really get going with this is there anything inherently wrong with putting subs inside cabinets. I could maybe have them sitting on a little acoustic foam if that would make any difference. I would obviously remove the sliding doors
Only bit that I'm not looking forward to is making grilles to cover the drivers as unlike some of you drivers showing is a big no no in my house with the good lady.
