I may well do that, but in the meantime I have seen a picture of an Antiference DX8A, and it looks suspiciously identical to the one I have. So perhaps it was some kind of OEM version that the aerial installer sold me from his trade stock (it came in a plain brown cardboard box)? If it is a DX8A, then according to Antiference it does have a balun.
At
http://www.antiference.tv/high-gain-dx8-0 you can read about the DX8
That's the one I was considering. Question is, for receiving Group A from about 25 miles away, will it be better or worse than a Televes DAT75? The chap two doors down the road has a DAT75 and tells me he has no problems with Freeview. (I realise the DAT75 is a wideband aerial).
And then the lady across the road has what looks like a "traditional" UHF aerial (simple cross-pieces rather than "X-shape" elements) and she says her Freeview reception is fine. The difference here is that my aerial points over tha road towards Crystal Palace, whereas hers is on the other side of the road, so maybe mine is vulnerable to passing ignition interference and hers isn't.
The Televes DAT75 has only about a 3dB increase on forwards gain over the DAT45.
What you can do with the DAT series is fit the Margin Raising Device (MRD) rather than the passive dipole. The MRD is powered from a PSU located in the house and for all purposes operates like a masthead amplifer except that it is located right behind the diople so is less susceptible to noise.
Antiference quote the DX8A with a forwards gain of 14.2dBi
Televes quote the DAT45 with a forwards gain of 16.5dBi
Televes quote the DAT75 with a forwards gain of 19dBi
Blake quote the DMX10A with a forwards gain of 14.65dBi
However the gain on the DAT wideband is not linear and the figure quoted is at the best point in the antenna's performance which is at about channel 62.
For the forwards gain in Group A on the DAT series, if I recall correctly from memory, (the slope graph is provided in Televes documentation on the www) is about 4dB less. So the DAT75 forwards gain would in Group A be about 15dBi 0.8dB better than the DX8A - so nothing!
However if the MRD is also fitted it will give another 13dB of gain. His this guy with the DAT75 got the MRD? - if so there will be a power supply for it in the house.
The DAT75 is really a big aerial, as you would have seen, and personally I would never consider this if I could manage with the DAT45.
Mathematically I think the DAT75 with MRD in Group A should give a forwards gain of about 28dBi
and the Antiference DX8A Plus a 10dB Masthead amplifier should give a comparable forwards gain of about 24.2dBi
4dB difference, just over twice power.
Increase the masthead with the DX8A to 13dB and they are both just about the same - from a forwards gain perspective.
If the noise is being introduced into the downlead, that is the level of impulsive noise is higher than the level of the signal then increase of the signal level in the cable could be the solution - so to improve the Signal/Noise ratio. - Fit a bigger amplifier at the masthead!
Also if you have unscreened wall plates upgrade these, solder the centre core of the coaxial to the center core of the BellingLee plug.
If the noise is being picked up by the aerial then tilt the aerial up, add a filter before the amplifier. Other option could be to try another location on your house for mounting the aerial.
