Impulse Buy.......Die Hard 1&2 DTS..R2
Discussion in 'Movie Forum' started by bob007, Feb 4, 2002.
  1. bob007
    bob007
    Have known about the R1 release a while, it's been on my list but never got round to ordering it.
    So whilst at the asda shopping with the better half this morning i noticed they were just putting it out on the racks (presume it's the R2 release date today) 99% of the time i order R1, but for some strange reason it jumped into my trolley.
    Does anyone know if there's any noticable difference between the two, i know it's a bit soon to compare picture/sound quality as it's just been released, so has anyone not ordered R1 and waited for R2? Should i have stuck with R1?
  2. mjn
    mjn
    May 24, 2001
    22,225
    Herts, England
    +10,053
    i got the region 1 version, when it first came out over 8 months ago....and it sounds/looks excellent...never seen the r2 version, but where is DH3 in the r2 boxset?
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    There is one quite major difference between the regions. The total absence of Die Hard With A Vengeance.
    Other than that noticable missing 'feature', everything looks the same.
    DH3 is released next month, but why not as a trilogy boxset?
    £40 for the R2 boxset, when you can pay the same for the R1 boxset with all three films in DTS, seems a bit steep to me.
    The R2 versions are probably quite badly cut.
  4. bob007
    bob007
    I wondered where D3 was......... brits short changed again...!!
    Have got the widescreen VHS copy of D2 certificate 18 where as the full screen version was only a 15 certificate, so i will be able to notice what cuts have been made on that one.
    If not totally satisfied will return them and spend my credit note on some beer, then order the R1 ..........fact: males go brain dead when food shopping...!!
    BTW asda's price was £34.97 so i slapped the cashiers bum on the way out...instead of mine ;)
  5. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    the right to die hard with a vengance are owned by beuna vista where as the other two are owned by 20th century fox, that why no R2 boxset with all three, same story with Jurassic park 12, and 3 (Columbia Tristar/Universal). I've got R1 version but aparantly the R2 version has had some of the scenes envolving the twin towers cut out of it, haven't seen it so I couldn't say for sure.
  6. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    Bought this today from Smiths, only £29.99. I like their pricing structure!
    Not bothered about getting R1 for this, didn't rate the third film much.
  7. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    Well the listing for the Die Hard Movie comparrison at Rewind lists R1 as an overall winner but the only differences seem to be some DVD-ROM features for if you want to play the disk on your PC.
    Both are anamorphic with DD5.1 & DTS tracks.
    R2 is PAL R1 is NTSC.
    So really I guess its down to price and maybe a 'marginally' better picture perhaps, due to a PAL transfer rather than an NTSC one.
    Hope that helps a little
  8. bob007
    bob007
    Watched DH1 last night ......didn't notice any cuts. But then it's been a while since i last watched this film.
    Picture and sound were............Dum De Dum Delightltful......:D
    If DH2 is of the same quality, then all my fears will have been laid to rest......and will never go food shopping again.....!!
  9. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    just watched DH1 in glorious DTS, it rocks. When Bruce droped the explosives down the lift shaft, the earth moved ! :D
  10. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    only difference I can find between the R1 & R2 sets is that the R2 disk of DH3 has about 20s of cuts. Not sure what is cut though.
    Regards
