Improving Picture on Xbox with LCD
Discussion in 'Xbox Forums' started by chrislad, Aug 12, 2005.
  1. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
  2. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    try a vga cable or component. thats if ya tv has the inputs :hiya:
  3. JUS
    JUS
    Jan 21, 2003
    3,179
    Plute
    +221
    Well I can't see a component or vga input on the spec. Nice price :)
    Are you definitely using a RGB Scart? If you are I think that's the best you can do without VGA or component inputs.
  4. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    There's no component on the LCD, but there is a VGA adapter (which is being used with my laptop so it's not free).
    I was talking about some internal Xbox software like Progressive Scan and what not. No real experience with different modes.
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,809
    167
    The Wheldon Road end!
    +7,970
    You need the MS HD pack (you can get it from Lik Sang) but as your TV doesn't have component input I guess you will have to use a component to VGA converter.
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,268
    103
    +490
    Alternatively get the X2VGA+ gizmo from www.x2vga.com & buy cheap console switch to switch the VGA inputs to your screen.
