Improving my screen
Discussion in 'Projectors, Screens & Video Processors' started by dUnKle, Aug 26, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,274
    +2,278
    Ok being on a tight budget I got hold of a blackout blind from Dunelm - a Little over 7ft by 7ft
    The projected image from my AE100 is very good, howver I do have a couple of problems
    The blind has to be attached to the ceiling and lowered into position - however when in position and displaying an image the there is a good 4 foot of plain blind on display - this is a major distraction and I feel hampers the image - is there a way of correcting this ? I dont think I can attach anthing to the blind as it has to be rolled up after viewing - could it be died ?
    The blind ripples slightly and is light so it can be prone to movement - would elastic straps pulling it tight help ?
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,274
    +2,278
    Anyone ?
    Have day off on Sunday and could do with making something good of it
  3. Voiceedit
    Voiceedit
    Jun 15, 2005
    80
    +4
    Try a piece of black blind material cut to the right size fixed to the top of the screen using Velcro. This will mask the exposed area of screen not used thus improving your viewing experience. It is easy to put on and take off - don't try rolling up the screen with the black mask still attached!!! Put the "softer" piece of Velcro on the screen edges - I assume you have some sort of black left and right edging to the screen as well!
    Good luck.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,274
    +2,278
    No edging at all :(
    Cant work out how to do it
