Willy
Hi there,
I just bought a Humax PVR-8000, but am finding some of the channels are getting pauses etc (or occasionally just not playing at all), which I'm assuming is down to signal strength. Usually the Strength comes up around 40-50%, with Quality at 100%.
So I was wondering about how to improve the strength. Unfortunately I can't replace the arial, since I live in a big block of flats, so the options that I can see are: 1) Get a digital booster, 2) Invest in better quality cabling (I'm using fairly bog-standard coax at the moment).
Anyone know if either of these are likely to help - or whether there's another solution I'm missing?
Cheers.
Edit - Oops: think I may have put this in the wrong folder.
Cheers.
