Importing tracks using sonic stage
Discussion in 'Headphones, Earphones & Portable Music' started by Emmodd, Jun 30, 2005.
  1. Emmodd
    Emmodd
    Mar 6, 2005
    180
    Sheffield
    +3
    I'm having some problems. When I try to import a CD into Sonic Stage i'm told I need to register with Gracenote and asked if I want to do it now. I click yes and...nothing. Basically, this means I have to go in and type album and track names. Any ideas?
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,223
    +6,428
    My bro had this problem on his PC....turned out internet access needed to be allowed on Zone Alarm firewall.
  3. the68gun
    the68gun
    Jun 20, 2005
    I had the same problem and it was solved by going into the proxy server settings in ss 3.1 and ticking the "do not use proxy" box. (Tools\options\CD drive settings\Get CD info\Do not use a proxy server)
    Worked for me! :clap:
  4. JamieL
    JamieL
    Sep 13, 2001
    41
    I've recently upgraded Sonicstage to version 3.3. However, now when I insert a cd the Gracenote registration message pops up, I click 'yes' and then nothing happens.
    Searching on the net suggests this is to do with proxy settings but I don't seem to be able to amend them as sugessted in the post above... I have no options on the 'Get CD Info' tab... please see the attached image
    [​IMG]
    Could anybody help... i reeeeally don't want to have to be typing out track names like I used to do prior to having an internet connection.
    Thanks,
    jamie
  5. peterjf
    peterjf
    Nov 27, 2005
    111
    +5
    When you installed SonicStage, did you get any error messages?
    My version 3.1 would not install itself properly and I had the same problem - I had to find the 'Sonic Stage add-on' on the CD and install it manually.
