importing cd's into sonicestage random track order
Discussion in 'Headphones, Earphones & Portable Music' started by jimton, Jul 11, 2005.
  1. jimton
    jimton
    Jun 15, 2005
    49
    sometimes when i import cd's to sonicestage the tracks apprear in a random order, does anyone know why and how i can change this? It tends to happen when i use copied cds iam using ss3.1 if that helps. :)
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,240
    +6,446
    not proper CD, so SS can't get song info off net, so can't record in right order? shouldn't happen should it?
  3. Aargh
    Aargh
    I have gotten this as well, what seems to happen is that the songs in sonic stage appear in a random order (but with correct track number), yet on the hd5 they appear in the correct order.
  4. jimton
    jimton
    Jun 15, 2005
    49
    also when i change track names then transfer them sometimes half the track name is missing or the artist name :mad:
