Importing an iPod from the US....
Discussion in 'Headphones, Earphones & Portable Music' started by Mr 928, Jul 15, 2003.
  1. Mr 928
    Mr 928
    Looking at buying a 30GB iPod from the US, either via ebay or using my friend in LA (and then fed-exing it back to me) - anything I should be aware of when I do this? :confused:
  2. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I know someone who did similar but they got stung by customs - it still worked out a bit cheaper than a UK sourced one though.
    Also another guy i know had one delivered to a US based friend and then paid them a visit and collected it - a cheap ipod and a holday. Doesn't sound bad!
  3. Mr 928
    Mr 928
    Thanks for the advice, but I think at this rate I'd may as well just bite the bullet and get one from Apple UK - less hassle I suppose!!
  4. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    True - and you'll have a proper warranty.
  5. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    remember EU the volume limit
  6. Mr 928
    Mr 928
    Good call. :smashin:
  7. sr78
    sr78
    Sep 26, 2002
    282
    I imported my iPod from the US. Had it replaced by Apple Holland because of a battery problem. Just enter the serial at their site, no problem whatsoever, I had a new iPod in two days!!! Apple offers worldwide guarantee.
    Only thing you should be aware of is that the adapter has a US plug. Fortunately, the plug is detachable from the adapter, and you can fit a standard power cable with a small female plug (as used on most small equipment, such as consoles) on one end and a UK/European plug on the other in it.
    That's it!
  8. Mr 928
    Mr 928
    What kind of money did you pay for it at the time? I must have the 30GB one!!!!
  9. sr78
    sr78
    Sep 26, 2002
    282
    I have the original 5GB version, about a month after is was released. I do know that even with shipping it was about €100 cheaper than buying one in Holland. Surely you can compare current US and European prices via Apple Store? :confused:
  10. Mr 928
    Mr 928
    Cheers :smashin:
    I'll look into it and find out what deals I can come up with....
  11. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Really? That good to know.
