Importing a DV Camera .....
bh
Other than the obvious VAT and import duty issues, I assume that to import a video camera from the US the following issues apply:
Different ac adaptor voltage (110volts)
NTSC output from analogue (connected camera --> TV)
DV output will be MPEG which can be either PAL or NTSC (when encoded to VCD)
Any other factors that need taking into account?
Thanks in advance.
A
Arthur.S
Yes...it's a loooooooong way to send it back if a problem crops up. With DV cams so cheap from UK based online 'e-tailers' (such as letsgodigital) why bother? Your standard consumer rights apply with a UK based company. Unless you specifically need an NTSC cam, I'd stay well clear.
LG CX 4K OLED TV Review: The best TV of 2020?
