onkeh
Title pretty much says it all. I was fiddling around with my Fedora install yesterday, since I had all the Xine libs installed anyway thought I would give a PAL DVD a go. Sure enough, it worked perfectly, looked very good as well
This guide will get you sorted:
http://www.fedorafaq.org/#dvd
