Import XBOX games
Discussion in 'Xbox Forums' started by THX THX THX, Oct 29, 2003.
  1. THX THX THX
    THX THX THX
    Bad trader
    Oct 11, 2003
    301
    16
    Lincs
    Does anyone know if it is possible to play imported games on a pal uk xbox without resorting to a modch*p?
    Cheers,
    THX THX THX
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
  3. phenom2003
    phenom2003
    I'd like to see the no-mod chip, region free game exploit. The only exploit which is of any use is the audio exploit which will run LINUX, not games.
    Rich
  4. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
  5. phenom2003
    phenom2003
    Indeed it does look like it can be done, but
    and how much effort would that take for every game. Best £30 you'll spend on your xbox, games are alot cheaper on NTSC (especially S/H), you also need a router to do this, chip the xbox, less hassle (ALOT). Also you need to make a back-up each game using FTP, so say £1-2 every game.
    Rich
