Import Gamecube help
Discussion in 'General Video Gaming Chat' started by mr_fantazmo, Jul 29, 2004.
  1. mr_fantazmo
    mr_fantazmo
    Hi all, i really need some help because i've just done something very stupid! I was re arranging some of my equipment around so i had a mess of wires all over the show. I went to plug my panasonic Q into the mains but it seems like i plugged my ps2 power cable into the back by accident, it made a clicking noise and now it wont turn on whatsoever, is the console proper ****ed?? The power was obviously too much for it as i normally use a stepdown convertor!! Any help would be great!! :lease:
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    yep you could have blown the psu inside of it
  4. krusty
    krusty
    yep youve blown the psu...............i did the same.
  5. krusty
    krusty
    on my q
  6. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Email London Console and ask them how much it would cost to fix (www.londonconsole.com)
    They specialise in console repairs/modifications etc and will be able to help. I've used them before and definitely recommend them
  7. mr_fantazmo
    mr_fantazmo
    Cheers for the replies, thank god it can be fixed, i was sweating a bit at first, i'll email that company and see what they say!! Hope it doesn't cost an arm and a leg!! By the way, just a random question, do all gamecube games have a 60 Hertz mode?? Coz when i play english super monkeyball on my panasonic q it has 60 hertz and is in colour, whereas R racing revolution plays in black and white! Anyway round this?? apart from buying the US version??
    Thanks again!!
  8. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    I think you need to hold down the B button while the game is loading, when 'Nintendo' logo appears, that will give access to select 60hz, if the game has it that is.
  9. mr_fantazmo
    mr_fantazmo
    By the way guys, londonconsoles no longer fix Panasonic Q's as they are, in his words, "a Bitch to fix!!" The only people i could find were Raven games who charge around £80 :rolleyes: So think hard and long if you have a few consoles and make sure you plug the right power cables to the right consoles, that'll teach me for rushing :suicide: . Now what do i do? Pay for it to be fixed or sell on Ebay and try and get some of my £300 back??
  10. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    get if fixed, or just get a UK Cube and get a Freeloader.
  11. sc1977
    sc1977
    Jul 16, 2002
    616
    kent
    +8
    did something a bit similar to my old dvd player i left the stepdown converter pluged in to the mains and disconected it from the player itself when i went to reconect it there as a blue crackle that jumped at my player and it died instantly upon internal inspection i saw a few capacators had blown i phoned my mate who knows a tv repair man and he just replaced the blown resistors/capacators with equal ones and it has worked fine ever since so you may not need to spend big money getting it repaired at a dedicated console shop have a look inside and maybe you can take it to an electrical engineer
    hope this helps
    stu :smashin:
  12. mr_fantazmo
    mr_fantazmo
    Cheers for the advice, however i've been doing some research and apparantly you have to completely strip the console to get the main componants at the bottom!! Apparantly it takes about an hour and a half to strip it, about 15 mins fixing it and another hour and a half putting it back together again!! Bloody stupid limited edition japanese hybrid devil machine!! :mad:
