I'm thinking of buying a harmon kardon dvd25 from the USA would it be ok to play through a uk tv ? also would the power supply be ok to use in uk? would this play pal dvd's or ntsc only? any advice would be grateful, thanks
Quite a few of us early adopters imported players from US in the early days and you will find many Pioneer 606 owners here. It will play through the most modern televisions but will require a transformer to adjust to UK voltage. These only cost £10ish though. Don't forget that it won't have scart outputs so you cannot use RGB and you may be limited to s-video or component signals.
Beware: most US/Japanese players are NTSC only and will not play PAL disc, not even using component (YUV).
With any USA equipment, ie receivers, power amps etc. is it really as simple as buying a transformer for £10. About 15 years ago I bought a simple $100 portable CD player and had all sorts of problems getting that to work in the UK. I bought bits and peices from Tandy or Radio Shack but had no real luck. I just spent a fortune on batteries!
