Impedance setting
R
ric_hall
Related to other posts, I am likely to purchase the Yamaha RXV396RDS along with a pair of Mission M72 speakers .
The speakers are rated:
Sensitivity SPL/m/2.83V 89dB
Nominal Impedance 8 Ohm compatible (min. 4.0 Ohms)
Amplifier Power 25 - 100W/Ch
The receiver is rated:
Minimum RMS Output Power 60W @ 8 Ohms
The problems lies with the impedance selection . The Yamaha receiver allows the user to select between two impedance settings .
The two settings are as follows(only listed for the main speakers):
If you use one pair of main
speakers, the impedance of
each speaker must be 4 W or
higher.
If you use two pairs of main
each speaker must be 8 W or
higher.
higher.
each speaker must be 16 W or
higher.
I will only be connecting one pair of speakers to the receiver .
Based on the above information, which impedance setting should I choose if I want the least damage to occur to both the speakers and the receiver(i.e. which setting gives the greater component longevity)?
Reiner
That would be the 4 Ohm setting as it halves the current of the power amp stage.
However, based on the specs provided (and that's include the sensitivity), I see no problem to use the 8 Ohm setting - especially not since you connect only one pair.
R
ric_hall
Out of curiosity, do the impedance values(requirements) change for a single pair of bi-wire capable speakers if you were to connect a bi-wire speaker cable to both the A and B front speaker terminals? - [the 396 has two sets of terminals for connecting two pairs of speakers at the same time to the one receiver]
Linked to this, in the 396 manual(pdf - online) mentions that you can set the receiver to select speaker pair A, speaker pair B, or both A and B for purposes of output . Would I be correct in saying that selection A + B would work perfectly well for the purpose of bi-wiring a pair of speakers, or have I misunderstood the meaning in the manual?
Reiner
The B terminal is intended for a 2nd pair of speakers in another room. However there is no problem in using it for the purpose of bi-wiring as the impedance of the LS (and thus the load to the amp) will not change.
Just select speaker A and B then and off you go .... :)
