impedance setting?
Discussion in 'AV Receivers & Amplifiers' started by CVEKE, Aug 29, 2005.
  1. CVEKE
    CVEKE
    Aug 17, 2004
    7
    Although I've found some info on this subject, I'd still want to ask this question:
    My receiver is Yamaha RX-V440RDS (rated 6x65W @ 8 Ohm/6x110W @ 4 Ohm, 270W power consumption).
    The speakers are Yamaha NS-P106 package (Sats/Centre: 30W nominal/100W max, 6 Ohm, Active sub 50W nominal /100W max)
    The receiver has a speaker impedance setting switch (4 Ohm min. for the main, 6 Ohm min. for the others in one position and 8 Ohm min. for all in the other position). In theory, I know that the correct setting for my setup is 4 Ohm. I also know that changing the position should not alter the sound in normal conditions.
    The thing is that changing the switch to 8 ohm increases the dynamic range of the sound (it can certainly be felt, the sounds become better defined and the bass is rock hard an still deep) while the 4 Ohm setting produces a silky soft sound, which is not bad, but lacks definition and dynamic (at least that's how it seems). The problem is that I'm not sure what sound I like better.
    There is slightly higher heat dissipation when the switch is to 8 Ohm. In 4 Ohm the receiver hardly heats at all.
    Finally the question is: Will leaving the switch to 8 Ohm position harm the receiver in some way on a long term?
    I would appreciate opinions on this subject. Also on the sound difference thing.
    Thx.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's unlikely. Most amps have thermal shutdowns. The impedance of a speaker is measured at a single frequency - its impedance can vary a lot at other frequencies, and manufacturers allow for this.
