cptflr
My amp manual is a bit limited on this topic, and the information I’ve found on the net is a bit confusing - should I set it to 6 ohms or 8+ ohms. If I understand correctly, it should be 6 ohms, but I don’t want to go blowing things up. I rarely need to operate the amp at even close to 50% power, so the question isn’t about maximizing power output or anything like that. Running the amp cooler would obviously be nice.
My setup - 5x 8 ohm speakers (Monitor Audio) + 2x 6 ohm speakers (Onkyo)
Thanks!
Thanks!
