G
Gazzza
I have a Marantz SR5400 receiver. The speaker connections on the back indicate you can use speakers with 6-8 ohms impedence.
I have therefore just purchased Missions M3S cinema pack, plus an additional sat, making it a complete 6.1 set.
The mission spec states these speakers are 8 ohms compatible.
I've received the speakers but when i came to install I noted on the back of each speaker it said "nominal impedence 4 ohms".
Can someone explain the meaning and significance of this ?
I'm assuming the fact that they state the speakers are 8ohms compatible means that i can happily drive them from my recieiver since the receiver states it will drive speakers with impedence from 6-8 ohms ? But it just worries me that the speakers state 4 ohms nominal imedance.
I guess there is a difference between nominal impedence and compatible impedence ?
Thanks for any help/info/advice.
Gareth
Gareth
