Hi Guru’s,
I am installing a B&W 7 series floor standers and central speaker. Along with 2 KEF sub’s plus 4 atmos speakers. I am refurbishing the whole audio room it has wall on one side and french door on the other. I am uploading a rough sketch (Forgive me sketch), I am now losing sleep on the french door reverb. I am having a big curtain which covers the doors. Hence reaching out to you to get some help:
1. Is there special curtain material we could get to absorb sound, so the sound dont reach the french doors? As i am planning to install some GIK products to catch the Echo’s on the opposite wall.
2. I am planning to install carpets instead of hard wood floor to reduce the sound bouncing off the floor. I cant treat the ceiling because of the atmos. So out of 4 walls, I can treat 3 as one wall is french. Can add the carpet but not the ceiling.
The room is echoing as it is before the installation, so hoping your advise plus some GIK products will help.
I am sure its not ideal, but something is better than nothing. But would appreciate your help and guidance.
Thanks & Regards
Mo
Thanks & Regards
Mo
