imon vs ati remote
Discussion in 'Desktop & Laptop Computers Forum' started by garyc, Apr 6, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    866
    Jersey, Channel Islands
    +13
    I'm currently trying to use ati remote with theatertek with some success but not entirely happy ie. pause button not working etc??
    Does the imon remote work all the theatertek controls, basically only want dvd control?
    cheers
    Gary
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I have both but usually use the ATI. The iMon has advantages, like remote power-on, more programmability and the option of teaching a universal remote, however the ATI's wireless operation is nice and the fact that there's a pre-configured file for TT 2 meant I didn't spend much time getting it running.
    Horses for courses really, both work well.
  3. garyc
    garyc
    Dec 21, 2002
    866
    +13
    What level of control are u getting from your ati remote with theatertek?
    ie. pause etc
    cheers
    Gary
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    As far as I can remember all controls are working, including the 6 user-configurable controls. Just to be clear, I'm referring to this ATI Remote Wonder.
    Which version of TT do you have? Assuming it's 2.x then are you using the updated ATI plug-in?
  5. garyc
    garyc
    Dec 21, 2002
    866
    +13
    yes TT2.... not installed the patch yet, not sure what that does?
    yes same ATI remote, went to this site for the plugin:-
    http://remotew.free.fr/plugins.htm.
    cheers
    Gary
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    The patch won't change anything related to this problem you're having.
    Try the user-supplied plug-in on TT's own web site (in the .ZIP on that page), make sure you extract the version for TT 2.0, that's the one I use.
  7. garyc
    garyc
    Dec 21, 2002
    866
    +13
    thanxs
    Out of interest what ati remote software are you currently running
    cheers
    gary
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Version 1.4. I tried the 2.x series but they're for the version 2 remote and wouldn't work with my original model.
  9. garyc
    garyc
    Dec 21, 2002
    866
    +13
    i went to the ati web site and they list 3.01 ver for ver 1 original model
    any thoughts?
    what other software do i require to drive a crt, i. powerstrip, dscaler etc
    cheers
    Gary
  10. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    My thoughts are to try the plug-in from TT's web site .. the ATI software I use is that which came with the device, which as I said was 1.4. I've no idea what could have been added in version 3.
    As to what software you need it depends on what you want to do. For DVD playback you'll want FFDSHOW if you want to do custom scaling etc., DScaler isn't too useful for this application except to try its' scaling plug-in for FFDSHOW but I've never felt the need.
    DScaler is used mainly with capture devices like Sweetspot when connecting things like cable/satellite STBs, games consoles etc.
    Powerstrip is useful/needed to set custom resolutions, this is mainly useful when using digital panel displays, how useful it is on a CRT depends on whether a non-standard PC resolution is beneficial, I have no experience with CRTs so couldn't say I'm afraid.
  11. garyc
    garyc
    Dec 21, 2002
    866
    +13
    FDDSHOW - thats a new one on me, what would that do for me?
    assuming TT2.0 for dvd play back?
    thanks again for all your help
    Gary
  12. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    You surely must have seen the many threads here discussing FFDSHOW. :eek:
    It's a software post-processor used mainly for DVD playback, its' main use is for image resizing when feeding, say, a hidef display such as a projector with a 1280x720 native panel size. It has many filters, such as Denoise and Sharpen.
    This is a good introduction to how to use it and what it can do.
  13. garyc
    garyc
    Dec 21, 2002
    866
    +13
    I know - I'm new to this side of things
    but as you say its the dogs, what version you running?
    oh - new ati remote software running with .dll & its works thin!! also tried the rear usbs and it works alot better!!! ashame the remote is a bit of a brick!!! so probably wont bother with an imon!!
    cheers
    Gary
  14. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    20041012_sse2 on a 3.0 P4 .. IMX there's no useful purpose using an later version, many users still use the 'Andy' version 20040709.
    Be warned, FDSHOW can seriously damage your DVD viewing time. :D
    Glad to hear the ATI's working now.
