iMon VFD issue : email causing exception
Discussion in 'Desktop & Laptop Computers Forum' started by Skunkpipe, Sep 17, 2005.
  1. Skunkpipe
    Skunkpipe
    I've got a problem with my home PC running iMon.
    It's a clean install or XPMCE and has the iMon drivers/software installed (no Multimedian though as this royally screws MCE up)
    All is fine and I can config the VFD to display all the bits and pieces I want with one exception (no pun intended)
    If I set up a couple of mail accounts to check for mail and display on the VFD the VFD driver at startup generates an exception error. If I modify the imon_VFD.ini file to remove the email option then all starts up correctly.
    Anyone else had an issue with this and found a solution?
