iMon Remote - Shutdown
Discussion in 'Desktop & Laptop Computers Forum' started by Barbarosa, Sep 11, 2005.
  1. Barbarosa
    Barbarosa
    Sep 1, 2005
    73
    Anyone using an iMon Remote (with the internally wired receiver)?
    I am trying to get the get the off button to put Windows into suspend rather than shutdown. The settings in windows/control panel/power options are correct and the computer goes into suspend if I push the front panel switch. This is a bit strange as the front panel switch is routed through the iMon receiver board. Any ideas?
  2. GLP1
    GLP1
    Sep 8, 2005
    209
    28
    +34
    Not sure if this is what you are after, but have a look at the bottom section of part two of the Silent Media Centre Build. From the adjusting bios settings.
    http://www.digitalhomemag.com/features/
    I have this all to come, when the blasted case arrives.......
    Gavin.
