reingam
Established Member
- Joined
- Nov 5, 2005
- Messages
- 929
- Reaction score
- 62
- Points
- 226
Here goes...
Every time I boot up i got the message VFD is not working properly, uninstall iMon then reinstall VFD.
So far I've uninstalled all iMon apps, and reinstalled VFD. That seems okay. Then I stopped VFD running and installed iMon 7.4xxx.
When the install is almost complete i get the following message every time:
The setting for "MCE Remote" is existing, do you want to use existing setting?
I've chosen "no", and it still then states setting up for MCE remote!!!
Now when I run the iMon app and go to setup MCE Remote is in there, greyed out. I deleted the remote, then have an option of adding 1 of the following 4 remote types - iMon RC, iMon RSC, iMon MM, iMon EX. No Imon Pad anywhere.
I chose the iMon RC option and clicked OK. As I do it then says setting up for MCE Remote! When I go back into the iMon app the only remote now available is MCE Remote, with no Add or Delete buttons, just a Reset button (which does nothing).
Any suggestions? this is driving me insane.
Lol I had a few problems trying to get the software up and running as well. The problem is that there's still settings on the OS for the remote that have not been removed by the uninstall. Go to programmes and settings in control panel and remove everything to do with IMon and Soundgraph. Then delete all IMon and Soundgraph folders. Restart and reinstall again. The option to select the pad should be available when you set up for the first time. It's strange that the selction for remote type is greyed out - hopefull the above will sort it for you. Also are you installing from the supplied cd or downloading the latest version from tinternet?
