Image Transfer
Discussion in 'Photography Forums' started by bigboss, Jan 2, 2005.
  1. bigboss
    bigboss
    Oct 6, 2002
    9
    scotland
    Hi , im a bit of a novice to digital cameras and want to know if i can transfer images from my pc to the sd card in my camera? I have a Pentax Optio S40 and use the acdsee software that you get with the cam. The reason for this is , i have a lot of images on the pc, could i pick certain ones , transfer them to the sd card then take the card to a shop and have prints made.I know that i could print them myself but i think it would work out cheaper to get them done elsewhere than using up the ink in my printer.
  2. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    I think you may be in bother unless your Pee Cee has SD/PC slots.
    I can insert any card and write to it as another drive, but if you are connecting camera to PC with a USB lead for transfer, I'm not sure if its two way.
    You could always burn your pics to a CD and take that to the printers.. :)
    regards
