image size
Discussion in 'Projectors, Screens & Video Processors' started by cube77, Aug 24, 2004.
  1. cube77
    cube77
    hi, my first post here so please be gentle...
    i have aquired a phillips screenpro 4100 projector, and have found a way to make it work with my current room set up. the only problem is the image projected is too big for the screen, is there any way of making the image smaller?
    there are no controls on the unit to adjust size
    any help appreciated.
  2. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
    According to Projector Central it doesn't have a Zoom lens, so the only way you will be able to adjust the image is to either move the Projector closer to the screen or vice versa.
