Image Retention On Halo 2
Discussion in 'Xbox Forums' started by cooky007, Mar 20, 2006.
  1. cooky007
    cooky007
    Hi everyone,
    I have been playing Halo 2 on my 360 and using a new (1wk old) LCD tv, running via component cable at 720 resolution. I have had some image retention. It only happens on Halo 2 and has happened twice in total. The image isnt there if I flick to a tv channel, but if I flick back to the component channel its there. I got rid of it by going into the Halo 2 menu system. I was worried that it may be a fault with my tv but it doesnt happen on any other games. Here are some pictures. Someone said this may be a common fault with halo 2.
    Has anyone else had this problem?
    Is it a common problem with Halo 2??
    top picture shows the problem covering the top half of the screen. The bottom picture is normal after flicking back to the menu.
    [​IMG]
    [​IMG]
    cooky
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,199
    +1,241
    Yes this happens on Halo2 . Looks like some sort of Z-mask hanging around. Its a glitch with the game on the 360.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Yes, i get this effect on my Sharp LCD.
    Nothing to worry about...:smashin:
  4. cooky007
    cooky007
    thanks guys, i just bought this new 40 inch LCD tv and its brilliant! I was SO worried there was something wrong with it because of this image retention. Feel very relieved now! :clap:
    cooky
  5. DIRY
    DIRY
    Mar 4, 2006
    232
    Cardiff
    Now that you've got that sorted :smashin: I'd move onto more worrying things - like running round with just a naff convenant blaster and an empty needler ;)
  6. bad ass
    bad ass
    Oct 26, 2005
    426
    +6
    lcd's dont suffer from image retention unlike plasma.......
    we have your panel at work, i think its something like an le40m61bd or something like that, I've had a sony hi def demo box up to it all week that got stuck and has stopped on the boot up sequence i.e. dos, when you start your pc with no retention at all.
    I would say that you have something called ghosting or you have something wrong with your panel
  7. cooky007
    cooky007
    dont think its my LCD because other people with plasma tvs have since reported the same problem with Halo 2. It doesnt occur on any other games / dvds / tv images. Plus, this screen has an 8ms response time, not likely to ghost with it being that fast matey!
    cooky
  8. royster
    royster
    The issue in halo is a bug in the backward compatability code. A lot of people have noticed it including me. Seems to happen on different levels.
  9. h3ckler k0ch
    h3ckler k0ch
    Unless you got a battle rifle to back up a fully charged shot!
    I get this retention too and it's proper annoying. Always seems to appear at the top half of the screen.
  10. bad ass
    bad ass
    Oct 26, 2005
    426
    +6
    I think your getting confused, lcds can't get screen retention full stop, plasmas onthe other hand can get screen retention/burn
