Image retention and leaving in standby
Discussion in 'Plasma TVs Forum' started by Leigh_1973, Dec 29, 2006.
  1. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    In view of my 427XD arriving next week i downloaded the manual and stumbled across a bit which said that in order to reduce image retention you should leave the TV in standby. Ive never left any TV in standby (fire risks and also power saving). So whats the idea then? to leave the set with a charge or something, and is this really necessary?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    If it was going to be fire risk it would not be sold in the first place.
    As for power savings forget it, these things take about 1 watt in standby. Leave your 100watt light on for an hour accidently is the equivilent of leaving the TV in standby for over 4 days.
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    I know that, but out of habit i always turn my TV off, so can you explain the reason behind the manual saying to leave the TV in standby? Just curious as to why its noted in the manual and gives the information to use this feature to stop image retention
  4. kevmarshall
    kevmarshall
    Apr 11, 2006
    1,609
    Lincolnshire.
    +209
    Perhaps it means leave in standby as opposed to leave ON and unattended.
    For instance, Sky picture could freeze and leave retention?
  5. wunduk
    wunduk
    Dec 16, 2006
    +3
    Yes, I think that this can be the only explanation. Standby won't supply power to the panel itself.
  6. chaparral
    chaparral
    Apr 8, 2006
    1,989
    Planet Earth
    +379
    There not even a button on my pioneer 436xde plasma to switch it completely off...
    And if i switch it off at the mains plug then i have to set the date & time went i switch it on again..:mad:
    I wouldn't be surpised if the pioneer 427 is the same..
    (I think you find most AV stuff is the same now days.E.G skybox,VCR,AV receivers,DVD recorders etc)
    Even my xbox360 only has a standby button.
  7. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    You could well be right, the manual doesnt explain it like that though. Sounds good to me.
