image quality from sky rf to pc then back again using DVI
Discussion in 'Sky Digital TV Forum' started by eternaldark, Nov 16, 2004.
  1. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    After reading a few posts regarding connecting sky to pc tv card and using that to watch sky on plasma, i gave it a try and must say even using rf! i was very suprised, solarisation was gone and picture was pretty good.
    Is there anything else i could do to the connection to make it even better?
    Another thing as well, i sometimes use the pc to watch dvds on the plasma using dvi and the quality is stunning, but i only get stereo, if i had a soundcard with optical out, would that enable me to get 5.1 surround if i plugged the output into the input on my surround kit?
    would be grateful for any replies :)
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Have you tried using an application called DScaler?
    It is quite a powerful tool to maniplate a video signal fed into the PC and then output via s-video/dvi or vga and feeding another display.
    Assuming you have an optical or coaxial digital output somewhere in the PC you can bypass the onboard soundcard processing and send the data straight to an offboard decoder/amp.
  3. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    will look into a new soundcard and have a look for dscaler too
    thanks
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
  5. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    thanks looks interesting, am playing about with dscaler at the moment, and very impressed with the picture i'm getting thru sky at the moment and thats using rf!!, cant wait to see the difference using rbg
  6. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    I've just installed a copy of DScaler as I run an RF feed from a Sky box into the tuner card of the PC and I have to say I'm stunned at the improvement in picture quality. It's got rid of all the tearing and even at full screen (1280*1024) the picture is a VAST improvement.
    John
  7. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    how can i get the image output from the pc to the plasma at full screen??
    when i watch a video on pc to it automatically outputs fullscreen to the plasma, but with dscaler it just appears in a corner of the screen!. Anything i need to adjust for it?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You could try an app called Powerstrip , it's a popular program used to manipulate video resolutions when sending to a second display and can be tied into DScaler.
    Not sure of the exact procedire though:(
