Image on a wall help
Discussion in 'Projectors, Screens & Video Processors' started by TheThingIs, Feb 20, 2005.
  1. TheThingIs
    TheThingIs
    Nov 28, 2003
    10
    Manchester, UK
    I have a completely flat wall that I want to use a projector on. I don't really fancy buying a proper screen for this and was wondering if it was ok to just paint the wall white? If so, what paint would be best, matt, silk or gloss or whatever?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    If it's smooth and flat, then it will be fine. Matt is the best. I use matt white, but people use light grey too. Once you get the correct size, you could even mask off and paint a black border if needed...PJ
