Imac To 3805
Discussion in 'AV Receivers & Amplifiers' started by rickyd, Aug 22, 2004.
  1. rickyd
    rickyd
    Jun 29, 2004
    1,200
    Nottingham
    +48
    HI ALL
    could anyone please tell me if it is possible to connect my mac computer to the 3805, so that i can listen to internet radio through the amp, and if so what and where do i connect!!
    thanks
    kinza.
  2. Lostinapc
    Lostinapc
    you'd have to do it using RCA wire from the headphone socket on the imac to the red and white plugs on the back of the amp, you can pick up a cheap one of these cables for £5 or more expensive ones for £20+
    hope it helps!
  3. rickyd
    rickyd
    Jun 29, 2004
    1,200
    Nottingham
    +48
    Thanks lostinapc
    will give it a go.
    kinza.
  4. nikyzf
    nikyzf
    Not quite "have to" :) If you have OS X 10.3, you could have a wifi connection to an Airport Express, which connects to the receiver using either a minjack-to-RCA lead, or Toslink digital. If you don't have or want an Airport card in the Mac, ethernet adaptors are available. :D
