imac and macbook
Discussion in 'Apple Forum' started by olimalaysia, May 27, 2008.
  1. olimalaysia
    olimalaysia
    Dec 16, 2004
    16
    got the imac, now i'm buying the macbook.
    how do i transfer all my apps from imac to macbook as i don't have cd's for the applications i bought online.
    any ideas?
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    40,352
    10
    13
    ::1/128
    +14,059
    The same way you transfer your data! Easiest is to use the transfer assistant and a firewire cable between the two. It will copy your apps and there preference all together...
    Please do make certain you do have the licenses to run them on both computers!
  3. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    Use Target Disk Mode
    You can also transfer Mail settings etc the same way.
  4. Chester
    Chester
    Aug 18, 2003
    3,589
    3
    137
    Peterborough, Cambs, UK
    +651
    Leopard's Migration Assistant allows you to do this across a network. Once you've setup your target Mac by clicking From another Mac and continue, a Use Network button appears that asks you to enter a code on the source Mac. Makes life a little easier if you don't have a FireWire cable.
  5. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    Correct me if I'm wrong but wouldn't it be slower than firewire if the network isn't all Gigabit?
  6. Chester
    Chester
    Aug 18, 2003
    3,589
    3
    137
    +651
    Yep, 100Mb/s is slower than 400Mb/s. Also there is much more encapsulation in Ethernet than FireWire. Incidentally there is a lot more control data in USB than FireWire too.
    However, if you have a network but don't have a FireWire cable, speed doesn't come into it.
