Im thinking of getting an x box
Discussion in 'Nintendo Forums' started by jonnyv, Apr 26, 2003.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Does anyone know a supplier of x-boxs in staffordshire or w.mids area ?
    Also anyone know about the various mod chips avaliable ? What do they do ?
    thanks
  2. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    Well... all the usual gaming shops for the XBox.
    As for mod chips, check out www.xbox-scene.com for a ton of good info. Make sure you do your homework tho as it can get a little complicated.
    I got my chip (Xecutor 2 Lite) from www.baldbouncer.co.uk who is a respected UK supplier of chips and he also does installs. A friend of mine has sent a couple of xboxes off to him and he'll install the chip for you and post it back next day.
    As for what they do, check out the forums on the two sites
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Thanks for the reply Mr Belowski, i have found a couple of site selling the Xecutor 2 Lite mod chip and pre modded x boxs, i shall try to find the best deal tomorrow
    thanks
  4. mr chadwick
    mr chadwick
    if you chip it,you wont be able to play xbox live.which is superb by the way.
  5. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    mr chadwick, you can use xbox live witha mod chip, they fit switches to turn the mod chip off...
  6. -Jay-
    -Jay-
    Jul 26, 2002
    4,882
    Kop End
    +135
    Yeah they do, but the only problem with that is if you forget to switch it off :rolleyes: it'll be game over mate.
