I'm sure this is an elementary question,
Discussion in 'Projectors, Screens & Video Processors' started by hebawom, Oct 4, 2004.
  1. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    I have a laptop connected to a projector. It can power 2 monitors. One is the laptop screen and the other the projector.
    When I load up the laptop, the PJ screen shows the wallpaper of my laptop without the icons, which is fine, the problem comes when I try and play a DVD through it. I've tried various players, when I press full-screen on all players I've tried, it full screens it on my laptop and nothing appears on the PJ - am I doing something silly?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    No you're not doing anything silly :) .. using dual-monitors at times is a bit of a black art.
    Basically, there's the condept of 'primary' and 'secondary' monitors. The 'overlay', ie. the sort of 'window' in which the DVD is rendered by default appears on the primary monitor.
    How you get it to appear on your projector will depend on the brand of video card you have, or more pedantically the drivers for it, and the operating system you're running.
  3. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    So, nothing to do with the settings in powerDVD then?
    On powerpoint, when you press the "Begin Slideshow" button, it full-screens to the projector, so why can't I do it with DVD's?
    If its a hardware thing, how do I change the settings?
  4. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Might be worth posting on the PC forum also it would help if you could let us know what Graphics card you have
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Powerpoint isn't using the Overlay, which is a special sort of window that is sometimes used to render video streams, ordinary Winows programs like Powerpoint don't use it.
    As Jon says, we need to know your software and hardware to help .. and the HTPC forums is your best bet. :)
  6. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    My graphics card is a mobility radeon. I don't know if that helps?
    But I'd really like to know how its done.
  7. [Slip]
    [Slip]
    Jan 28, 2004
    190
    +4
    if you're using multiple monitors I'd really recommend a utility called Ultramon (google it, it'll come up)
    Gives you two taskbars etc but more importantly gives you lots of nice shortcut keys to manipulate programs by moving them from screen to screen.
    i.e. I have Alt+Q set to move a program from one screen to the other. You could do the same and it will move PowerDVD to the secondary screen (the PJ)
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    'Fraid I've no experience of those and when using dual-monitors my primary display is the projector so this isn't an issue for me. Since no-one in this forum has been able to offer any help then I think you really would be best re-posting in the HTPC area. :)
  9. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Reading the original post on this thread, I don't think this has anything to do with multiple monitors etc. If you connect another monitor to a laptop, there is usually a function key on the laptop marked lcd/crt. by toggling this key (varies from machine to machine, I guess, but it's a marked function key on my Dell laptop), you can direct the output of the laptop to either the laptop screen only, both laptop and connected monitor or to the connected monitor only. You need to toggle this key so that the display is your connected monitor only (in this case your projector). Use whatever the standard resolution for the projector is (ie SVGA or XGA,) or if it's a wdescreen panel projector, use a resolution which matches that of the LCD or DMD panels.
    Sean G.
  10. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    Many many thanks to whoever suggested ultramon.
    This is exactly what I wanted.
    A thousand thanks.
    Consider this misplaced thread closed!!
  11. [Slip]
    [Slip]
    Jan 28, 2004
    190
    +4
    Happy to help :)
