Im Stuck on HL2 - Please help
Discussion in 'PC Gaming & Rigs' started by AndyW, Nov 19, 2004.
  1. AndyW
    AndyW
    Hi guys, hope you can help. I've got to the bit on HL2 where im on the jet ski contraption. After a while of skimming through the sludge people started shooting at me and eventually I reached some gates that were closed. Unable to get through I got off the jet ski and climbed up some steps and went into a room with large vehicles in it. After that I fought past a machine gun point and killed some guards in another room before reaching a valve that usually can be turned, which im assuming is used to open the gates. Unfortunately this valve is damaged, has sparks flying from it and im at a loss for what to do. Ive tried retracing my steps but I cant see anywhere to go or find any way of opening the gates.
    Please help this very frustrated gamer!
  2. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +432
    Spoiler:
    The room after the machine gunner - go through the door and you will see some barrels ( flamable ) on the right ( the broken valve is on the left ) - shoot one with the ( lowest ) pistol a couple of times till it catches fires then quickly back through the door - this blows up the winch and the gates open
    end spoiler:
  3. AndyW
    AndyW
    I'll give it a try, thanks for your help!
